manxmann3 Posted December 11, 2013 Report Share Posted December 11, 2013 Evening all. Ive not ridden my 05 4rt for about 6 months and today went to start it and nothing. Id serviced the bike 6 month back, oil change, air filter, NEW plug. The bike did run spot on after oil change etc. So checked the plug by holding it againt the exhaust and its not sparking on every kick? Is this normal? Was old fuel but ive put fresh in tank as well. Thanks for any advice! Quote Link to comment Share on other sites More sharing options...
honda_freak Posted December 11, 2013 Report Share Posted December 11, 2013 (edited) Hi Yes it should make a spark on every kick. But remember when you kickstart it not to let the engine turn too slowly. Then there are the stop button that could disturb the ignition system if button are stuck in a specific position. Have you tried with a new sparkplug despite of that you replaced it last time you had it started ? Do you have a mutimeter and to you know how to use it ? Regards Honda Freak Edited December 11, 2013 by honda_freak Quote Link to comment Share on other sites More sharing options...
blocky Posted December 11, 2013 Report Share Posted December 11, 2013 Using the exhaust to earth the plug is not advisable as generally speaking they are rubber mounted and cannot really be relied upon as a good earth. Quote Link to comment Share on other sites More sharing options...
manxmann3 Posted December 11, 2013 Author Report Share Posted December 11, 2013 Thanks fellas. I got a mate to earth the plug and its sparking well. just i wasnt cranking it hard enough by hand whilst holding the plug to earth. Now im thinking i could have another proble. Its so long ago that i used the bike, i think i might have used old 2 stroke fuel or really stale fuel! Theres a really odd smell to the fuel i removed from the bike earlier. Could this of blocked the injector? Im clutching at straws here! Thanks Quote Link to comment Share on other sites More sharing options...
nelly1 Posted December 11, 2013 Report Share Posted December 11, 2013 does it smell a bit like varnish if so very bad fuel Quote Link to comment Share on other sites More sharing options...
manxmann3 Posted December 12, 2013 Author Report Share Posted December 12, 2013 Yeah really strange smell. Could it have blocked something with having 2t oil in it? Quote Link to comment Share on other sites More sharing options...
scraggydog64 Posted December 12, 2013 Report Share Posted December 12, 2013 Have you reset the ECU by holding the throttle fully open and giving it two or three slow kicks (With the plug in.). Both of ours fired straight up after months of standing after a reset of the ECU. Quote Link to comment Share on other sites More sharing options...
manxmann3 Posted December 12, 2013 Author Report Share Posted December 12, 2013 Yep tried that one too thanks. Nothing doing. Must be a fueling problem? Quote Link to comment Share on other sites More sharing options...
german munster Posted December 12, 2013 Report Share Posted December 12, 2013 The idle-speed must be about 1.900 rpm, so turn it up, and normaly it must start. Quote Link to comment Share on other sites More sharing options...
honda_freak Posted December 12, 2013 Report Share Posted December 12, 2013 Until now what have you checked ?. It could be a problem with fuel supply and one way to rule that out - is to spray a small amount of diesel start into the intake system and listen for that diesel spray to ignite in the combustion chamber. Regards Honda Freak Quote Link to comment Share on other sites More sharing options...
nelly1 Posted December 12, 2013 Report Share Posted December 12, 2013 id start by draining out the old fuel Quote Link to comment Share on other sites More sharing options...
thats_a_five Posted December 13, 2013 Report Share Posted December 13, 2013 Remove the seat and air filter. Spray some starting fluid in the intake and give it a kick. Spark and fuel should at least make a pop or two. If so, then it is probably a fuel supply problem. You have drained all the old fuel, right? With fuel in the tank you should be able to disconnect the fuel line from the injector and see if the fuel pump is working. If it is, then remove the injector, reconnect the fuel line and see if the injector squirts fuel. If it is, and you have spark it should start. Let us know what you have done and the results you get. Good luck Quote Link to comment Share on other sites More sharing options...
jj65 Posted December 13, 2013 Report Share Posted December 13, 2013 Do you know anyone that has a 4rt, if so, borrow the complete fuel system(tank,hose and injector) and try it on yours, if it starts, it's a fuel problem. Next thing to do then, strip the fuel tank, drain the fuel out of the pump and filter, clean everything, power up the fuel pump to see if it's working, flush everything with fresh fuel. If your fuel tank/pump has rust in it, that could be your problem too. Quote Link to comment Share on other sites More sharing options...
