dazzagreener Posted December 13, 2013 Report Share Posted December 13, 2013 Right I got my engine out stripped down as far as I can go but I have still got the gear on the end of the crankshaft to come off so I can strip it further. I can't seem to get the nut off. The last time I done this I used the flywheel but it just sheeted the key and then used a impach wrench and that worked. But for some reason the wrench ant working this time. So has anyone got any tips to get the nut off. Cheers Quote Link to comment Share on other sites More sharing options...
tltel Posted December 13, 2013 Report Share Posted December 13, 2013 pop it in to your local garage or bike shop and get them to use an air gun on it. TLTEL Quote Link to comment Share on other sites More sharing options...
bulto58 Posted December 13, 2013 Report Share Posted December 13, 2013 Blow torch, and give it a bit of heat. Quote Link to comment Share on other sites More sharing options...
dazzagreener Posted December 14, 2013 Author Report Share Posted December 14, 2013 I'm going to take it into work today and use there air gun. I used a snap on battery one just hope the air gun has a bit more beans to it to undo it. Quote Link to comment Share on other sites More sharing options...
dazzagreener Posted December 14, 2013 Author Report Share Posted December 14, 2013 We'll that done it air gun at work and a special impact socket. The socket is shaped like a flower instead of flats. Also had a bit more slack to create an hammer affect. Engine now split and please to find to noisy main bearings. Cheers. Quote Link to comment Share on other sites More sharing options...
dadof2 Posted December 14, 2013 Report Share Posted December 14, 2013 Glad to see you got it off. I hold the pinion with stillsons using aluminium between their jaws and the pinion to avoid damaging it. Never use heat on a pinion (or any other gearbox component) as it only takes about 250 degrees celsius to start undoing the heat treatment that gives the pinion its strength and wear resistance. Quote Link to comment Share on other sites More sharing options...
copemech Posted December 15, 2013 Report Share Posted December 15, 2013 Although I normally mark these and put them back to torque with a rattlegun, It did just occur to me that one might simply use a torque wrench and a holding socket/ ratchet on the other end while bring both the gear and flywheel up to the 72 lb/ft rating at the same time upon reassembly! Quote Link to comment Share on other sites More sharing options...
