toetoe Posted December 18, 2013 Report Share Posted December 18, 2013 i have been doing about half an hour a day, just on my balance but with the engine off, my progress was really slow, i could manage about 5 seconds at the very best until i read through some of the posts and over night i can now do over one minuet, i couldn't believe how much easier it is bye letting air out of my tyres and standing in the correct way, tomorrow i am going to start learning to balance after coming to a stand still with the engine running, is their any other tips that you could share with me, that could make it easier or is it just the same as doing it without the engine running and plenty of practice. Quote Link to comment Share on other sites More sharing options...
lineaway Posted December 18, 2013 Report Share Posted December 18, 2013 Are you running correct tire pressure? 4 and 7. Or Flat? Remember to practice with the wheel turned in either direction. Use foot pressure to regain balance. It takes hours. Might have fun with stopping and restarting the bike from a balanced position. 2 Quote Link to comment Share on other sites More sharing options...
wobblenorbed Posted December 18, 2013 Report Share Posted December 18, 2013 Have you done any trials yet ? Try practicing balancing whilst waiting in the cue after you`ve walked the section of course, don`t know why but I find it easier when I`m all warmed up after doing a couple of sections. Also there is normally an incline knocking about too just to mix it up a bit. Good luck. Quote Link to comment Share on other sites More sharing options...
toetoe Posted December 18, 2013 Author Report Share Posted December 18, 2013 i have done about six hours, i will have transport shortly after xmas, i hope but until then all i can do is use a small garden at the front of my flat and about a 15 foot piece of land that is along the side of my flat so i am restricted to what i can do, i would go on a trial tomorrow if i could get there, just for fun and their isn't really anyone to take me, without it costing me a fortune this is why i am practicing the things i can do until i have transport. Quote Link to comment Share on other sites More sharing options...
2stroke4stroke Posted December 18, 2013 Report Share Posted December 18, 2013 Theoretically it's easier with the motor running as you have the gyroscopic effect of the crankshaft, therefore it's better to practice without the motor - you also save petrol and keep the neighbours happy! Quote Link to comment Share on other sites More sharing options...
thats_a_five Posted December 18, 2013 Report Share Posted December 18, 2013 I find it easier to balance by turning the wheel to one side, focusing my attention on a spot about 15 feet (5 meters) in front of me, and using just the bars to correct my balance. Also leaning a little forward to put more weight on the front tire helps. Quote Link to comment Share on other sites More sharing options...
toetoe Posted December 19, 2013 Author Report Share Posted December 19, 2013 i noticed that if i concentrate on something, i'm fine but as soon as i move my head i lose my balance, so thats something i can improve on, i take it that when they say 4 and 7 for tyre pressure it is 4 in the rear and 7 in the front, my front at the moment is around 5 so i can increase the psi slowly as i progress, i have also got a concrete block in the garden, so i thought of riding over it but stoping with the rear tyre on the block to change things up a little, i will just have to be patient while i'm waiting to get transport, thanks for the help everyone. Quote Link to comment Share on other sites More sharing options...
thats_a_five Posted December 20, 2013 Report Share Posted December 20, 2013 Tire pressure depends on the surface. I usually run 5.5 to 6 in the front and 4 in the rear. Lower pressure in the front will allow the tire to bite in making it easier to balance. Quote Link to comment Share on other sites More sharing options...
sherconoob Posted December 20, 2013 Report Share Posted December 20, 2013 +1 on the previous comment about it being easier with the engine on. if you can do well with the engine off it will be dead easy when actually riding. agree also on trying with the front wheels both ways, it's easy to just favor your preferred side. Quote Link to comment Share on other sites More sharing options...
toetoe Posted December 22, 2013 Author Report Share Posted December 22, 2013 i can go almost as long as i want with the front wheel turned to the left but not so good with it turned to the right so i'm practicing more with the wheel turned right, the tyres are now about 3psi in the rear and 4 psi in the front, for some strange reason if i put my foot on the back break i can balance much better, i also practice changing gear at the same time as balancing so it breaks the concentration, when i can do over 2 minuets with the wheel turned left and right i put a little bit more air in just the back tyre then do it all again and put a small amount of air in the front, it's all i can do for the moment but i have just had a letter from the dvla saying that they have sent a letter to my doctor and as soon they get a letter back saying i'm fit to drive i can then go to proper practice areas and get involved with a club and trials meetings, very soon i hope. Quote Link to comment Share on other sites More sharing options...
lineaway Posted December 22, 2013 Report Share Posted December 22, 2013 Yes, you usually hold on the front brake. Not so much rear brake as you need to be able to use the feet. Quote Link to comment Share on other sites More sharing options...
