Sump Bolt
scarboroughbeta
Ratchet straps and temporary threaded bar. If the straps do not pull the sump close enough then fit the back sump guard bolts through the sump guard and into the frame, cut the threaded bar to two suitable length pieces and thread into the front fixings through the sump guard, the wind the sump into position with nuts and washers on the threaded bar. Once the sump guard is in position remove one threaded bar at a time and replace with the original fixings (if it is really bad you may need to clamp the plate once it is in place while you remove the threaded bar)
Edited by jfc
