Clutch Problems Help Needed Please
mattyn666
iv have a 321 1999 gas gas which i bought spares or repairs, has a clutch issue. the slave cylinder on the side of the motor has cracked. apparently the man tried bleeding it and the pressure cracked the casing. how would this happen?
obviously someting not right or been put back together wrong. is there a diagram of the layout of componets in order like you would get in a manual about?
should there be a ball bearing either side of the metal bar which runs from the clutch to the slave or just one on the clutch side? just trying
as the bikes bin in bits before i dont know if everythig is thereor in correct order.
