4T Surging?
bigbird2
My 2009 Evo 300 generally starts and runs OK but under hard acceleration it sort of surges unevenly and sometimes bogs a little on hard or even mild throttle application. This surge/bog continues thru increasing revs at full throttle.
I'm not SURE but it seems like adding some choke may help but not cure these problems a little?
I'm guessing this means either:
- There is crap in the carb?
- AND/OR The jetting is too lean for cold weather?
Plan is to take carb apart to clean it and find out what the jetting is.
Is there something else I should be doing different or beyond the above?
Does anyone have jetting recommendations? I don't know where in the documentation to find this info?
THANKS! for any help.
Have you had the carb appart earlier?.... If so you may have the CV bellows boot pinched as they are a SOB to put together properly.
As above, raise the needle all the way( lower the clip to the bottom groove) to get a stronger richer midrange
