Rev 3 Radiator Fixing
hoggyf
Doing a bit of maintenance on the bike and I noticed a loose fixing on the radiator at the bottom then noticed both bottom fixings are loose? Is it supposed to bolt right through from the front of the rad through the rubber bushing and frame??
Just a thought but what holds this in? Haven't tried removing it properly but even with the nut off the back it was held tight, tempted to drill through it and bolt right through as a temp repair until getting some new ones
