Can I Run My 199A Castrol Power Racing 1
bultacorock
Looks indeed very nice and sorted. The " older" aor box is much better then the smaller one from the model 199A.
I would replace the gas throttle against an Amal or Domino unit both works nice and have a much better cable routing.
The only thing I can think of is mounting a mudflap between rear wheel and swing arm, which prevents mud clogging up the space in muddy conditions. It depends to your local weather conditions, were I live with much rain and a ground that is based mostly of clay and sand a must have, (likewise a good chain guard).
  • Like 2
Hi Pschrauber
Thanks for the feed back its always good to get some feed back from you, The older style air box came with the bike i did not understand why it had been fitted but as you say, i was told by
other bultaco riders on here to keep it its bigger and better for the engine and will help it to breathe easier. Will fit a mud flap thanks for that tip, it can get really muddy were i ride. I will be ordering some bit for my bike and will get a Amal throttle.
All the best
BR
Edited by bultacorock
