lister_st46 Posted January 1, 2014 Report Share Posted January 1, 2014 I have recently bought a 2008 txt pro 280 and I am new to the sport. I've noticed that there is a 'clutch oil/transmission oil' leak coming from the bottom bolt of the clutch cover. The dealer fitted a new gasket on Monday and returned the bike but this hasn't stopped the leak. I have a couple of questions; 1. Is this a common fault? 2. What torque should these bolts be tightened to? 3. I have noticed that motomerlin supply a 'mk2' clutch gasket (made from gasket material unlike the oem part). Has anyone replaced the gasket with this part? thanks Quote Link to comment Share on other sites More sharing options...
lineaway Posted January 1, 2014 Report Share Posted January 1, 2014 No, they should not leak. Usually just requires a new gasket. Does leak when parked, or only when you ride it? If it leaks only when ridden, check the kick start seal as it is easy to become pushed out. Quote Link to comment Share on other sites More sharing options...
lister_st46 Posted January 1, 2014 Author Report Share Posted January 1, 2014 Thanks, to be honest I haven't yet ridden the bike for longer than 20 mins. I noticed the leak after the bike had been parked in the garage over night. Loos as if the leak is coming through the bottom clutch housing bolt and is collecting of the sump guard. I've checked the kick start and this looks dry. The oil is pink so I'm certain it's not engine oil. Quote Link to comment Share on other sites More sharing options...
wobblenorbed Posted January 2, 2014 Report Share Posted January 2, 2014 On 1/1/2014 at 9:04 PM, lister_st46 said: Thanks, to be honest I haven't yet ridden the bike for longer than 20 mins. I noticed the leak after the bike had been parked in the garage over night. Loos as if the leak is coming through the bottom clutch housing bolt and is collecting of the sump guard. I've checked the kick start and this looks dry. The oil is pink so I'm certain it's not engine oil. Hi your bike doesn`t use engine oil. Just gear oil. Quote Link to comment Share on other sites More sharing options...
g0mjsmike Posted May 4, 2014 Report Share Posted May 4, 2014 hi i just had this problem i put new £4.00 geskit in and it leaks from the bottom bolt and it will not stop so in end up got paper geskit cost £2.00 and its stopped now . :rolleyes: cheep is best hi Quote Link to comment Share on other sites More sharing options...
houseape1000 Posted May 7, 2014 Report Share Posted May 7, 2014 I bought a metal/rubber gasket from splatshop for ~£10.00 from Splatshop that worked a treat. Before this I tried a standard paper gasket and gasket compound which didn't fully seal it. http://www.splatshop.co.uk/gasgas-clutch-cover-gasket.html Quote Link to comment Share on other sites More sharing options...
