Slow Pick Up/flat.
cabby
While out the other day a couple of guys who are a hundred times better riders than me had a shot of my bike and both of them remarked on how flat/slow a pick up it had then just fired up.
Something that I have thought for a long time but just thought it was my rubbish control, anyway, what can I do to resolve this issue ?
2012 250 on standard gearing and everything else as it was the day it was new ?
A 250 is hard to find here, and I got a "12 250 because I prefer it over my 2.9 prior, less aggressive and easier to ride, good for us punters, maybe not for better riders, yet I like mine just fine.
I have not messed about with the ignition timing on this bike, yet It seems set docile, one might advance it a bit for more aggressive power, go slow, a mm or two on the plate rotation, prolly no more than 3-4mm max. as you may then get into the kickback and easy stalling range.
So is there nothing much more i can do than than to improve things ?
Adjusting the idle wasnt great. I was wondering if changing the gearing or pilot would make a difference ? Both of which are simple enough to do with my lack of technical skill.
Well, now that you mention it, if you have no idea where the jetting is currently, it would be a good start!
My "07 2.9 came with a #30 pilot that was soo lean it would not lift the front wheel!
With the stock Dellorto, I figure you should be at a 36/ 118(120) on the pilot/main jets, with the main being a bit less critical.
And since it seems you have not done it, you now get to learn to fight getting the intake pipe and adapter all fit nicely back in place on the carb, what a joy! Good luck!
Don't take it off the carb then, much easier to get on & off the airbox
Pretty sure when I still had the dellorto fitted to my bike the jetting was very close if not the same as Copemech has provided
Not sure there is any choice on the new bikes, as the top if the U shaped intake tube is set in the airbox(tank)!
As others have covered here, Make sure carb is clean and the needle is on the right clip position and installed correctly, Check ignition timing. Normally a bike that is weak off the bottom then takes off is a sign of a lean condition.
Could also be an air leak, This would make the revs slower to drop down to idle and make the bike slow to initially pick up from idle then of sort of make the bike want to run away when reved.
Have you ridden another 250 to compare it with? Does yours have a flywheel weight?, Could be that your mates are used to a bigger engined bike.
Ok quick update.
I have readjusted the fuel screw to give me more fuel, i.e. just over 3 out rather than the 2.5 it was. I have adjusted the idle accordingly, however, I haven't ridden it in a trial yet (since I have adjusted it that is) so it may well have been running lean.
The bike is completely standard from new, nothing has been done to flywheels, jets.
As for where I am, Dundee, Scotland, and yes, the couple guys who rode it the other day, do ride bigger capacity bikes, bith have 280 scorpas, but I don't hold it against them.
