agricon Posted January 6, 2014 Report Share Posted January 6, 2014 (edited) Hi all Has anyone had experience with replacing the front fork bushes on a TLR 200 (35mm forks)? I have a set stripped down for an overhaul and noticed that the bushes are showing signs of wear. How easily should they come out? Interestingly, there is no part number showing in the parts manual for the bushes! Maybe they are not supposed to be replaced? Any help appreciated. Edited January 6, 2014 by agricon Quote Link to comment Share on other sites More sharing options...
zerorev3rev4 Posted January 6, 2014 Report Share Posted January 6, 2014 Make sure you can find replacements before removing Quote Link to comment Share on other sites More sharing options...
jkmr1 Posted January 10, 2014 Report Share Posted January 10, 2014 Not sure if this will help. http://www.cmsnl.com/honda-tlr200-reflex-usa_model1107/partslist/F++07.html#results Quote Link to comment Share on other sites More sharing options...
agricon Posted January 11, 2014 Author Report Share Posted January 11, 2014 On 1/10/2014 at 9:01 AM, jkmr1 said: Not sure if this will help. http://www.cmsnl.com...07.html#results Hi jkmr1 yes i've seen this and it the same as my manual. It doesn't show the bushes that are within the fork leg. Cheers Quote Link to comment Share on other sites More sharing options...
bashplate Posted January 12, 2014 Report Share Posted January 12, 2014 are there deffo bushes in there?????? or do the stantions run direct in the alloy slider? Quote Link to comment Share on other sites More sharing options...
agricon Posted January 13, 2014 Author Report Share Posted January 13, 2014 On 1/12/2014 at 5:52 AM, bashplate said: are there deffo bushes in there?????? or do the stantions run direct in the alloy slider? Hi bashplateYes I'm pretty sure,unless im going mad? Here are a couple pf photos looking down inside the leg. This shows the top bush This photo shows the top and lower bush plus the plastic/nylon sleeve between them. You may understand now why I find it strange that I can't find a part number in the Honda parts list. I may just take them out and then try to match them with something from another bike. Quote Link to comment Share on other sites More sharing options...
tlrmark Posted January 13, 2014 Report Share Posted January 13, 2014 The 33 mm fork on the reflex does not use bushings. The 35 mm fork on the TLR competition model does use syntallic bushings. The parts diagram shown above is for the 33 mm reflex fork, without bushing. Contact any Honda dealer in a country in which the real TLR (not reflex) was sold, and they will have a parts book for your fork. The real TLR competition was not sold in North America, only the dual sport reflex. Not sure if New Zealand Honda imported the competition TLR back in the day or if individuals brought in bikes on their own from England, Japan etc. Quote Link to comment Share on other sites More sharing options...
bashplate Posted January 15, 2014 Report Share Posted January 15, 2014 nice one Mark....that clears it up. Quote Link to comment Share on other sites More sharing options...
