Txt Pro 125 2003 Cooling Fan On All The Time
nastyroxinc
Hi all.
The fan is now running all the time on the above bike. It seems to have been doing this since I last cleaned it. The coolant level is ok, all I've done so far is check the two connections on the thermo sensor with a multimeter and with a cold engine it gives 100% continuity across them. Before I order a new one, is there anything else I need to investigate?
Cheers.
Hi check the pipes from the water pump are getting warm? If the pump fails the coolant will trigger the thermostat but without the circulation from the pump it won't cool and the fan will stay on. Seen this a few times
