petecam Posted January 7, 2014 Report Share Posted January 7, 2014 Hi I have a Witter detachable swan neck towbar on my car. I wanted to fit a bike rack but they all only seem to fit on fixed towbars. However I found this adaptor on EBAY http://www.ebay.co.uk/itm/Bak-rak-Swan-Neck-Towbar-to-Flange-Adaptor-/181192074209?pt=UK_Car_Accessories_Touring_Travel&hash=item2a2fe3a3e1 Anyone used one or would think this would be OK? Thanks Pete Quote Link to comment Share on other sites More sharing options...
jamo_duval Posted January 7, 2014 Report Share Posted January 7, 2014 You can get a bolt on type swan neck Tow Bar. I've got one on mine made by Witter although there are other alternative brands out there I'm sure!! I don't know how sturdy that one on ebay might be as it might want to rock n' roll about on the Tow ball. Quote Link to comment Share on other sites More sharing options...
joeninety Posted January 7, 2014 Report Share Posted January 7, 2014 It looks a neat solution but I wouldn't be using it for anything more than a push bike. With a trials bike and rack you are on the edge weight limit wise and I've found if the flanged mount bolts if aren't stupidily tight then the bar that stays on the car can twist. With that design you have a huge moment force held over a small area... Quote Link to comment Share on other sites More sharing options...
petecam Posted January 7, 2014 Author Report Share Posted January 7, 2014 (edited) Jamo: They dont make the "Flange Detachable" type for my car which is a shame as that is a perfect solution. I might have to just buy the no detach flange towbar and fit! Joen: Yes it's a lot of pressure on one ball point, I was wondering if it would twist as well! Edited January 7, 2014 by petecam Quote Link to comment Share on other sites More sharing options...
jordi Posted January 7, 2014 Report Share Posted January 7, 2014 Have a look at Westfalia Tow Bars, they make a replacement part for the swan neck that gives you a fixed flange. Quote Link to comment Share on other sites More sharing options...
telecat Posted January 7, 2014 Report Share Posted January 7, 2014 My Towbar is a Witter detachable Flange version so no problems. Might be worth checking to see if the Flange will fit. Quote Link to comment Share on other sites More sharing options...
petecam Posted January 7, 2014 Author Report Share Posted January 7, 2014 (edited) They don't make a detachable flange towbar (which is a newish product) for my car as its a Saab and Saab is no more. So my options were retro fit a flange fixed towbar or try the adaptor in my orignial post. I dont really want to get rid of the detachable bar as the wife moans about getting her dress dirty on the towbar :-) So I emailed the suppler of the adaptor and it's rated up to 100kg, so I have ordered one and will give it a try. I will update the post and let you know how I get on! cheers Pete Edited January 7, 2014 by petecam Quote Link to comment Share on other sites More sharing options...
maxbikes Posted January 7, 2014 Report Share Posted January 7, 2014 no way will this work,maybe ok for push bike,but not motorbike.ive carried motorbikes for years on normal tow bars,and even bolted on tight the flanges still twist slightly with bike on. 1 Quote Link to comment Share on other sites More sharing options...
anotherfive Posted January 7, 2014 Report Share Posted January 7, 2014 I use a brink detachable towbar. I add to this an adapter for a motorbike rack from Pendle engineering. Loads on the ball are still less than a twisting van beleive me. never had a problem Quote Link to comment Share on other sites More sharing options...
richt Posted January 7, 2014 Report Share Posted January 7, 2014 I have a Witter towbar fitted to mine, they have one main beam that fits the car (check their website) and with choices of; 1) fixed swan neck, 2) fixed flanged type. 3) detachable swan neck, 4) detachable flanged type. They can be swapped to suit your needs. Quote Link to comment Share on other sites More sharing options...
mike_dowson Posted January 8, 2014 Report Share Posted January 8, 2014 I use one of the adaptors with a fixed swan neck and haven't had any problems carrying a Beta Evo 300 4T. The rack doesn't rock at all, but can rotate about the ball slightly (but can't go very far). This easily fixed with a rope or tie-down at each end of the bike up to the roof bars. 1 Quote Link to comment Share on other sites More sharing options...
jkendall Posted October 13, 2015 Report Share Posted October 13, 2015 I just found this post when looking for a similar solution. There's no flange type available for my car so at present the adapter is looking the only way forward. Just wondered if anyone else had had any further experience with these / good or bad... Quote Link to comment Share on other sites More sharing options...
