wobbler Posted January 7, 2014 Report Share Posted January 7, 2014 Fantic Guru's, I just need a bit of help - I've added an 80 air cooled mono to the stable - similar to the one pictured below ...except normal 32mm forks and non reservoir rear shock. I could do with any manuals etc as I need 1- Fork oil capacities 2 - Gearbox oil capacities An in depth parts diagram would be ideal ..... Has anyone uprated the suspension so it will take a 12 stone adult ???? Thanks in advance for any help As always the wobbler Quote Link to comment Share on other sites More sharing options...
grib Posted January 7, 2014 Report Share Posted January 7, 2014 (edited) There are parts diagrams here for the model you have posted a pic of and some newer/older ones too (the 50cc parts diagrams cover the 75/80cc too); http://info.motorsyk...lekataloger.htm they aren't exactly what you want but may be of use. Edited January 7, 2014 by grib Quote Link to comment Share on other sites More sharing options...
wobbler Posted January 7, 2014 Author Report Share Posted January 7, 2014 Grib- thanks again for your help-they're a good start Cheers The Wobbler Quote Link to comment Share on other sites More sharing options...
