Ty250 Engine Size
cleaner
If you want to stay around 250cc, then get the bore measured by the person who will be reboring it. They will tell you from that what size oversize piston to buy. You should always get the smallest oversize that will clean up the bore, so you then have more options for the next rebore.
If you want a bigger displacement, you can get pistons up to 2.0mm (0.080") above standard diameter off the shelf made by Wossner, which increases the capacity.
TY250 motors can also be made 320cc but this is a lot more expensive because there is a new sleeve and more machining required, and rejetting, and a heavier flywheel
