ady witting Posted January 11, 2014 Report Share Posted January 11, 2014 Hi everyone, I've Just bought a second hand X Light, but it has 2 sidewall cuts, it takes a week to go down. should I change to a different tyre or just keeping blowing it up. Quote Link to comment Share on other sites More sharing options...
richt Posted January 11, 2014 Report Share Posted January 11, 2014 if you can ride with it carry on and get some wear out of it. even a new tyre can go flat in a week if the rim tape is leaking. Quote Link to comment Share on other sites More sharing options...
nelly1 Posted January 11, 2014 Report Share Posted January 11, 2014 if you can ride with it carry on and get some wear out of it. even a new tyre can go flat in a week if the rim tape is leaking. too expensive not to get your moneys worth Quote Link to comment Share on other sites More sharing options...
kramit Posted January 11, 2014 Report Share Posted January 11, 2014 Hi everyone, I've Just bought a second hand X Light, but it has 2 sidewall cuts, it takes a week to go down. should I change to a different tyre or just keeping blowing it up. Mine goes down 2 lbs per hour!.....buy a new tire and send yours to me. Quote Link to comment Share on other sites More sharing options...
thats_a_five Posted January 11, 2014 Report Share Posted January 11, 2014 If the cuts are deep and you think the cords might be compromised, you might want to put a patch on the inside to avoid a blowout at a bad time (like section one of the next trial). X-lites do have a tendency to have slow leaks through the sidewalls. I have heard of people using some kind of bicycle tire sealer in them. If the leak is slow enough, I agree with others - just check it before you ride and enjoy. Quote Link to comment Share on other sites More sharing options...
guys Posted January 11, 2014 Report Share Posted January 11, 2014 If the cuts are deep and you think the cords might be compromised, you might want to put a patch on the inside to avoid a blowout at a bad time (like section one of the next trial). X-lites do have a tendency to have slow leaks through the sidewalls. I have heard of people using some kind of bicycle tire sealer in them. If the leak is slow enough, I agree with others - just check it before you ride and enjoy. I had the same problem with my X-light. This product sealed it: http://www.notubes.com/Sealant-C14.aspx (Is very popular by mountain bikers) 1 Quote Link to comment Share on other sites More sharing options...
