cliff montesa Posted February 7, 2014 Author Report Share Posted February 7, 2014 Thanks for that 'feetupfun'. Does it not loose a bit of oil out of that hole then? especially if you are climbing??? Quote Link to comment Share on other sites More sharing options...
feetupfun Posted February 8, 2014 Report Share Posted February 8, 2014 (edited) Thanks for that 'feetupfun'. Does it not loose a bit of oil out of that hole then? especially if you are climbing???there is a chamber inside where that hole is, and that chamber is connected to the gearbox by a small passage. The passage between the chamber and the gearbox is located in a way that avoids oil going from the gearbox to the chamber If you don't like that design, you can always block that hole and install a vent in the filler cap. The Montesa design actually works pretty well (on my bike anyway)and I've not heard of anyone complaining about it. Edited February 8, 2014 by feetupfun Quote Link to comment Share on other sites More sharing options...
