stpauls Posted January 13, 2014 Report Share Posted January 13, 2014 Hello I have just removed two of the clutch springs in my clutch, to try to give it a lighter pull. I am trying to refit the clutch inspection cover o-ring, which seals the case to keep the oil in. However, every time I try to put it in the recess, it just falls out. Is there a special way of doing this? Thanks in anticipation Tony Quote Link to comment Share on other sites More sharing options...
bilks Posted January 13, 2014 Report Share Posted January 13, 2014 Put a smear of silicone grease in the recess. Quote Link to comment Share on other sites More sharing options...
nelly1 Posted January 13, 2014 Report Share Posted January 13, 2014 Put a smear of silicone grease in the recess. same here Quote Link to comment Share on other sites More sharing options...
0007 Posted January 14, 2014 Report Share Posted January 14, 2014 Sometimes the o ring streaches when you pulle cover Will it lay in the groove or does it seem too long High Tac spay works great for o rings Quote Link to comment Share on other sites More sharing options...
stpauls Posted January 18, 2014 Author Report Share Posted January 18, 2014 Hello All Thanks for the replies. I leaned the bike over on it's side, then smeared a tiny bit of silicone grease down in, around the recess. It stayed in place until I refitted the cover. Thanks for the help. Tony Quote Link to comment Share on other sites More sharing options...
