penno350 Posted January 19, 2014 Report Share Posted January 19, 2014 Fitting a PVL to my C15 but it doesn't have any instructions. Could anyone please confirm the position of the 4 spacers provided with the kit? 3 are obviously for the stator and one for the rotor. However, if the rotor spacer is fitted to the crankshaft behind the rotor there is hardly any thread protruding. Similarly should the stator spacers be behind or front side of the stator? Thanks. Quote Link to comment Share on other sites More sharing options...
big_red_bike Posted January 19, 2014 Report Share Posted January 19, 2014 Hi when i fitted the pvl to my triumph twin all the spacers were wrong .The crank spacer i turned down untill the crank nut would fit fully on.Then i adjusted the stator spacers untill the stator ran central with the stator. Quote Link to comment Share on other sites More sharing options...
penno350 Posted January 20, 2014 Author Report Share Posted January 20, 2014 Thanks for the response. Confirms my thinking that it doesn't really matter as long as you have clearance and alignment. Quote Link to comment Share on other sites More sharing options...
