bully m92 Posted January 25, 2014 Report Share Posted January 25, 2014 Can anyone help me source a new seal holder? as you can see this one is totally shot!! I've never seen one with such a deep insert. Cheers guys Quote Link to comment Share on other sites More sharing options...
woody Posted January 25, 2014 Report Share Posted January 25, 2014 They have the deep insert for the engines that have only a single main bearing on the clutch side Quote Link to comment Share on other sites More sharing options...
woody Posted January 25, 2014 Report Share Posted January 25, 2014 If you've tried the usual sources, you've probably overlooked John Collins at JC Motorcycles, Port Talbot. He has used Bultaco parts. You could also try Wakefield Offroad as they have broken lots of trials bikes over the years. 1 Quote Link to comment Share on other sites More sharing options...
bully m92 Posted January 25, 2014 Author Report Share Posted January 25, 2014 Cheers woody, don't suppose its possible to put 2 bearings in to take up the space? Quote Link to comment Share on other sites More sharing options...
pschrauber Posted January 25, 2014 Report Share Posted January 25, 2014 Orlando Calonder in Switzerland, ( former main Importer for Bultaco for the continent and still in business) Quote Link to comment Share on other sites More sharing options...
bult360 Posted January 25, 2014 Report Share Posted January 25, 2014 I would be suprised if i dont have one , i will look later and pm you 1 Quote Link to comment Share on other sites More sharing options...
bully m92 Posted January 25, 2014 Author Report Share Posted January 25, 2014 Cheers bult much appreciated mate :-) Quote Link to comment Share on other sites More sharing options...
woody Posted January 25, 2014 Report Share Posted January 25, 2014 Cheers woody, don't suppose its possible to put 2 bearings in to take up the space? I don't know. Not sure if the crank is suitable for 2 bearings so I can't give you a definitive answer. However, I can't see any obvious reason why a later holder without the deeper insert couldn't be used. But I could be missing the obvious... By the way, you only use a gasket or an O ring, depending on which holder you have. Not both together. Quote Link to comment Share on other sites More sharing options...
bully m92 Posted January 25, 2014 Author Report Share Posted January 25, 2014 I don't know. Not sure if the crank is suitable for 2 bearings so I can't give you a definitive answer. However, I can't see any obvious reason why a later holder without the deeper insert couldn't be used. But I could be missing the obvious... By the way, you only use a gasket or an O ring, depending on which holder you have. Not both together. Cheers woody, i was wondering whether to use a different holder. I realised about just using the o ring, or the gasket.Thing is if i use another holder, will it affect using the wear sleeve, or do they all have the wear sleeve? Cheers Hywel. Quote Link to comment Share on other sites More sharing options...
woody Posted January 26, 2014 Report Share Posted January 26, 2014 Can't help with that as I've never had a 199 engine apart so I don't know how the sleeve differs / locates on that engine Quote Link to comment Share on other sites More sharing options...
davey64 Posted January 26, 2014 Report Share Posted January 26, 2014 A company called Motos del Abuelo do various seal housings, http://www.motosdelabuelo.com/ Click on the Bultaco parts catalogue and they are on page 22. I emailed them last week with a drawing of mine which I think is the same as yours, 15.5mm deep from gasket face to inside face. The price is 22 euros but the P&P is a bit steep at 30 euros. Like I said in an earlier post, if I can't get hold of a decent used one I'm going to machine one so if you're stuck give me a shout and I'll make two but I wont be able to get on it for a couple of weeks. Dave. Quote Link to comment Share on other sites More sharing options...
bully m92 Posted January 26, 2014 Author Report Share Posted January 26, 2014 Thanks Dave much appreciated. I think bulty may have one, but is he doesn't i'll let you know. Cheers Hywel. Quote Link to comment Share on other sites More sharing options...
bully m92 Posted February 1, 2014 Author Report Share Posted February 1, 2014 Thanks Dave much appreciated. I think bulty may have one, but is he doesn't i'll let you know. Cheers Hywel. Quote Link to comment Share on other sites More sharing options...
bully m92 Posted February 3, 2014 Author Report Share Posted February 3, 2014 Hey guys is it possible to install 2 main bearings, on the clutch side of a 199? Quote Link to comment Share on other sites More sharing options...
