redfly16 Posted January 25, 2014 Report Share Posted January 25, 2014 My chain came off today and started to coil around the front sprocket snapping the little alloy crank case breather off I have the right angled bit, but the part that pushes into the crank case has fell inside the crank case. Any ideas how to get it out other than pray it comes out with dropping the oil. Can I take this side of the crank case off or do I have to start with the clutch side and work my way back. Many thanks Quote Link to comment Share on other sites More sharing options...
