bondy Posted January 27, 2014 Report Share Posted January 27, 2014 hello guys ive took the swing Arm off to change the bushes. only to find the boss and bushes have been modified looks like the plastic outer bush as been turned down. looks like theres been a sleave welded in on the inside theres a lip for some reason i dont know. so the only thing i can think of doing is to buy the standard bushes.and have them turned down to fit.hears some photos any beter ideas would be greatful. Quote Link to comment Share on other sites More sharing options...
mike350 Posted January 28, 2014 Report Share Posted January 28, 2014 Hi Bondy, I changed mine (199A) last summer and from memory it looked exactly like yours does. It was a pig of a job to cut out the brass bushes but it all went back together pretty easily once cleaned up and greased. I don't think yours has been modified. Good luck! Quote Link to comment Share on other sites More sharing options...
bondy Posted January 28, 2014 Author Report Share Posted January 28, 2014 it has been modified 2 sleeves has been welded in treee quarters down the boss. thats what you are looking at in the first photo. the plastic outer bush has been taken out by me. i have orderd new brass bushes. i will have the new bushes modified to work with the modified swing Arm. the gap between the 2 inner bushes where the engine mount gose as been made smaller. Quote Link to comment Share on other sites More sharing options...
