tonyp Posted January 28, 2014 Report Share Posted January 28, 2014 I'm not sure whether the 2nd and 3rd gears on my bantam engine have already been swopped over. If you want to lower the gearing on a transmission then you go for less teeth on the driving end and more on the driven end. So, in the gearbox, am I right in assuming I should end up with the 22 teeth cog on the output shaft, and 21 on the other shaft ? Quote Link to comment Share on other sites More sharing options...
smelling123 Posted January 29, 2014 Report Share Posted January 29, 2014 http://www.flickr.com/photos/76022002@N08/8582856835/ You should end up with the 21T on the output shaft and the 22 on the layshaft. 1 Quote Link to comment Share on other sites More sharing options...
totalshell Posted January 29, 2014 Report Share Posted January 29, 2014 yup just done this tonight.. again. fiddle but all sorted now.. you actually move 4 cogs not two.. Quote Link to comment Share on other sites More sharing options...
charlie prescott Posted February 2, 2014 Report Share Posted February 2, 2014 (edited) Hi Guys, Just about to do the gear swop, and had lost the diagram, need to look no further now thank Smelling. Last time I messed with gears I lost some skin on a sharp one or two so be careful. Regards Charlie. PS works now Andy, just need to log on and off???? Edited February 2, 2014 by charlie prescott Quote Link to comment Share on other sites More sharing options...
andy m Posted February 2, 2014 Report Share Posted February 2, 2014 There were some low 2nd and high 4th gears produced, unfortunately the supplier was taken ill. Quote Link to comment Share on other sites More sharing options...
charlie prescott Posted February 2, 2014 Report Share Posted February 2, 2014 Hi Guy's. Hi Andy, Is that who I think It is ?? Regards to you and him Charlie. Quote Link to comment Share on other sites More sharing options...
