bigmike1961 Posted February 2, 2014 Report Share Posted February 2, 2014 How do you go about changing the fork oil on a 2005 scorpa? Any advice/good links much appreciated. Thanks. Quote Link to comment Share on other sites More sharing options...
lineaway Posted February 3, 2014 Report Share Posted February 3, 2014 I would check out a sherco website as the forks are close to being the same. Quote Link to comment Share on other sites More sharing options...
bigmike1961 Posted February 9, 2014 Author Report Share Posted February 9, 2014 Used the sherco site for the levels http://www.shercousa.com/pdfs/2006fork.pdf Used this site for the set up http://www.thehellteam.com/catalogue/c11/c27/c74 The right leg with the damper was the most trouble - difficult to get all the oil out. The damper rod stays attached but the tube slides down, pumping he damper seems to get most of the oil out. Volumes of oil given were too much so I went with height from the top of the tube. Have to see how it rides next trial. Quote Link to comment Share on other sites More sharing options...
cactusjack Posted February 11, 2014 Report Share Posted February 11, 2014 (edited) You should always use an air gap when setting up forks as this gives you the most accurate measurement. This is a link to the workshop manual for an SY250F, however I am pretty sure they ran the same forks, so using this as a guide should sort you out. http://www.scorpausa.com/manuals/sy250fchassis.pdf Edit to add the linky! Edited February 11, 2014 by cactusjack Quote Link to comment Share on other sites More sharing options...
bigmike1961 Posted February 11, 2014 Author Report Share Posted February 11, 2014 (edited) Thanks for that Link cactusjack. The levels are exactly as stated in the Sherco site. That's what I ended up going with. Edited February 11, 2014 by bigmike1961 1 Quote Link to comment Share on other sites More sharing options...
cascao Posted February 11, 2014 Report Share Posted February 11, 2014 This is a good help http://www.splatshop.co.uk/blog/2013/01/paioli-ceriani-fork-oil-levels-for-sherco-trials-bikes-from-2006-to-2011/ Quote Link to comment Share on other sites More sharing options...
