rainey88 Posted February 4, 2014 Report Share Posted February 4, 2014 Right just bought a 250 racing 2012 model and its pinking quite abit under load etc and when riding about. Take it this is from running too lean? Havnt had the carb off yet which i will be doing friday afternoon. Just wondered if anyone else has had problems and what to check first. Thanks. Quote Link to comment Share on other sites More sharing options...
rainey88 Posted February 6, 2014 Author Report Share Posted February 6, 2014 Or anyone know how a keihin carb should be set up? Quote Link to comment Share on other sites More sharing options...
5again Posted February 6, 2014 Report Share Posted February 6, 2014 Similar experience with new to me 280 Racing. Went from middle needle clip down one, ok in sections but pinky on the going, still needs to go down another slot to the bottom notch. Actually suspect the slide needs to be richer, but at £60 will try make it better with the needle. Quote Link to comment Share on other sites More sharing options...
rainey88 Posted February 6, 2014 Author Report Share Posted February 6, 2014 Im new to these carbs and until iv had it in bits tomorrow i dont really know what im looking at, does anyone know of a diagram to explain this a it better. I thought it may of been down to the jets and just mixture and air screw? Quote Link to comment Share on other sites More sharing options...
rainey88 Posted February 16, 2014 Author Report Share Posted February 16, 2014 Right so iv tried adjusting the needle went down with the clip and went up with the clip. Hasnt really made any difference at all :/ Quote Link to comment Share on other sites More sharing options...
lineaway Posted February 16, 2014 Report Share Posted February 16, 2014 Try two steps bigger on the pilot jet. Quote Link to comment Share on other sites More sharing options...
dadof2 Posted February 16, 2014 Report Share Posted February 16, 2014 Plug grade and colour? Float height? Air filter clean and oiled? Squish clearance? Grade of fuel? Make of fuel? Age of fuel and how long since mixed with oil? Quote Link to comment Share on other sites More sharing options...
rainey88 Posted February 18, 2014 Author Report Share Posted February 18, 2014 Hi dadof, Not sure with the plug will have to up date when i go out and check the bike. Fuel is super unleaded from a total garage. Brand new fuel mixed the day of riding which has been the weekend. How do you check your float height and squish clearance? Filter is cleaned and oiled after each ride or checked to see if it needs doing at least. Quote Link to comment Share on other sites More sharing options...
tltel Posted February 18, 2014 Report Share Posted February 18, 2014 squish and float adjustment have been covered loads of times you should be able to search for them on the forum. Might be worth taking the exhaust off and looking at the top of the piston to see if its coked up. TLTEL Quote Link to comment Share on other sites More sharing options...
rainey88 Posted February 18, 2014 Author Report Share Posted February 18, 2014 Ive recently changed the head insert and didnt think the piston was that bad, maybe should give it a clean so its spotless ? Quote Link to comment Share on other sites More sharing options...
tltel Posted February 18, 2014 Report Share Posted February 18, 2014 I don't know anything about head inserts, but maybe re-jetting is the answer. Was it pinking before you did the head. TLTEL Quote Link to comment Share on other sites More sharing options...
rainey88 Posted February 19, 2014 Author Report Share Posted February 19, 2014 Yeah it was doing it before i changed it, so a bigger on the jets then ? Quote Link to comment Share on other sites More sharing options...
lineaway Posted February 20, 2014 Report Share Posted February 20, 2014 Like I said, go up two sizes on the pilot. If it fixes it, come summer go down one size and see how it is. Funny thing about all the jetting Gurus out there, the pilot jet flows from idle to wide open. If the bike is running, the pilot is flowing. 3 Quote Link to comment Share on other sites More sharing options...
rainey88 Posted February 24, 2014 Author Report Share Posted February 24, 2014 Can anyone with a racing tell me if after the keihin carb do they have the rubber adapter that the airbox slots onto? If i remember rightly a while back someone made alloy adapters for the dellorto is there any for the keihin? Quote Link to comment Share on other sites More sharing options...
rainey88 Posted February 27, 2014 Author Report Share Posted February 27, 2014 Also plug is quite black but oily too Quote Link to comment Share on other sites More sharing options...
