elliotsdaddy Posted February 6, 2014 Report Share Posted February 6, 2014 Hello fellow owners. I have recently become the proud owner of a 2007 Sherco (obviously) 290. Now, I have never owned a trial bike before and I am unsure as to the essentials that need to be carried out with regards maintenance etc. I'm after advice really on things like...how often to change the air filter? what fuel-oil ratio to use? What pre/post ride checks/maintenance need to be done? tyre pressures, stuff like that. I'd like to know all the things that an experienced rider would do without really thinking about it. Any advice, tips or recommendations are welcome. Thanks, Chris. Quote Link to comment Share on other sites More sharing options...
cabby Posted February 6, 2014 Report Share Posted February 6, 2014 Give the air filter a good clean and oil, but not over oil. Not sure how much gear oil is in the 07 model but mine is 500mil but usually put in around the 450 mark 60-70mil of two stroke oil per 5 litre petrol can ( try and use good petrol Shell vamx or the BP equivalent) 6 in the front and 4 in the back for tyres unless it's a minging muddy ole day and go 5 and 3 Generally go round checking the bolts/nuts are tightened as they have a habbit of coming loose. Sure there is much more to do but canny think at the moment but others with far more knowledge than me will be along soon enough to keep you right. Quote Link to comment Share on other sites More sharing options...
carlsmith Posted February 6, 2014 Report Share Posted February 6, 2014 I have a 2010 290. I use 12.5ml of two stroke per litre, so 62.5 ml per 5l. That's 80:1. Carl Quote Link to comment Share on other sites More sharing options...
lewis cosgrove Posted February 6, 2014 Report Share Posted February 6, 2014 (edited) http://www.lewisportusa.com/manuals/sherc_11-21-09/sherco_setup_and_lubrication_guide.pdf Clean carb, airfilter and maybe airbox. Its best to make sure all three of these things are dirt free with the airfilter oiled correctly. Are the fork seals leaking? Do the stem bearings feel smooth? WD40 all moving parts regularly (kickstart, gear lever, pegs, chain etc) Any major play in the rear suspension linkage? A strip, clean and grease can help. Clean and lightly oil the throttle, make sure the throttle pings back when released. Do the brake lock up easily? Everything tight? Edited February 6, 2014 by lewis cosgrove Quote Link to comment Share on other sites More sharing options...
lockie28 Posted February 6, 2014 Report Share Posted February 6, 2014 80 ML OF GOOD SYNTHETIC OIL TO 5 LTRS OF FUEL!! 450ml of gear oil changed regularly .... check nuts and bolts regularly clean carb every couple of outings drain water from airbox / clean air filter it goes on and on ....... Quote Link to comment Share on other sites More sharing options...
lewis cosgrove Posted February 6, 2014 Report Share Posted February 6, 2014 80 ML OF GOOD SYNTHETIC OIL TO 5 LTRS OF FUEL!! 450ml of gear oil changed regularly .... check nuts and bolts regularly clean carb every couple of outings drain water from airbox / clean air filter it goes on and on ....... "it goes on and on" ..................................... Quote Link to comment Share on other sites More sharing options...
cabby Posted February 6, 2014 Report Share Posted February 6, 2014 I have to say I think 80ml is far too much oil per 5lt for trials bikes. Fine if you're doing road trials but in the main you'll not burn off the excess oil that will build up just pottering around at a local trial. Quote Link to comment Share on other sites More sharing options...
lockie28 Posted February 6, 2014 Report Share Posted February 6, 2014 "it goes on and on" ..................................... And on ........... Quote Link to comment Share on other sites More sharing options...
copemech Posted February 7, 2014 Report Share Posted February 7, 2014 Good reading here! http://www.shercousa.com/?action=6 Quote Link to comment Share on other sites More sharing options...
elliotsdaddy Posted February 7, 2014 Author Report Share Posted February 7, 2014 Well there is a lot of great advice there so far chaps so thanks. I've got a fair bit more of an idea than I had. http://www.lewisportusa.com/manuals/sherc_11-21-09/sherco_setup_and_lubrication_guide.pdf Flippin' good link that Lewis, thanks very much. Good reading here! http://www.shercousa.com/?action=6 .....and another one, thank you copemech. One question though, I see a lot of people debating the oil ratio issue. Some say 80:1 some 70:1 etc....what exactly would be the difference between a bike running 80:1 and a bike running say 60:1? Would it just be a case of the higher the ratio of oil the more the bike would smoke and feel slightly sluggish? Quote Link to comment Share on other sites More sharing options...
lewis cosgrove Posted February 7, 2014 Report Share Posted February 7, 2014 (edited) You really aren't going to feel the difference between 50:1 to 80:1. There is no universal ratio for every bike, it depends on how you ride. Are you mostly just putting about? 70:1 / 80:1 will be fine. Riding fast in high gears a lot? The factory recommended 50:1 will give you peace of mind. Anywhere from 50:1 to 80:1 will do for any circumstance though. Just pick what you think is most suited. Here's a link that goes into detail. http://www.trialscentral.com/forums/topic/48320-oil-mixture/ Edited February 7, 2014 by lewis cosgrove Quote Link to comment Share on other sites More sharing options...
copemech Posted February 8, 2014 Report Share Posted February 8, 2014 Pay particular attention to the bits in the reading that state "DO NOT RUN THE BIKE AFTER WASHING WITHOUT CHECKING AIR FILTER AND BOX FOR WATER!" OR JUST REMOVE IT AND BLOCK THE HOLE BEFORE WASHING IS SOMETIMES SIMPLER! 1 Quote Link to comment Share on other sites More sharing options...
elliotsdaddy Posted February 8, 2014 Author Report Share Posted February 8, 2014 Cheers chaps. I'll definitely block the intake before washing and I'm gonna go for 80:1 I think. If the rain holds off tomorrow I'm gonna go for my first potter around the woods for an hour and see how many times I can fall off. Quote Link to comment Share on other sites More sharing options...
