dadof2 Posted February 16, 2014 Report Share Posted February 16, 2014 Are you sure the seal grooves really are absolutely clean. Any chance mineral oil has contaminated brake fluid - it will cause the seals to swell giving problems you described. Damaged seals do not usually cause piston sticking, they just leak Quote Link to comment Share on other sites More sharing options...
