Bantam Taper Roller Steering Head Bearings.
old trials fanatic
There isn't one that fits straight in, I had some sleeves made to take a std off the shelf bearing set. Without stripping I can't advise. If you use a decent bearing supplier they should sort out the nearest to your head stock and yoke stem size. The sleeves sit in the headstock the bearings drop in.
Hi Guy's.
Hi Blocky,
Look I will do the page on my web site ,about the tools and the jig this week end.
I have promised to do it for a long time , and have most of the pictures!
Just need to do the wording.
The tool for swaging the headstock is quite simple to make, and takes the size down to 47mm, to take an available bearing, and well worth doing.
Glad you enjoy BSA Otter.Com.
That's what I built the site for ?to give information about building up Brit Bikes, and where to get the parts to do this ,with less hassle .
"Britshocks" are still possibly the cheapest class, to get into Classic trials riding. If you use your head and not your wallet? To much anyway!!!
Regards Charlie.
  • Like 2
