Tlr200 Lengthen Swing Arm
trialtrial
Hey guys, I dont have my TLR200 restoration bike yet, still keeping my eye out (pretty hard to find in Canada). In the mean time, I have been reading and reading the various restoration projects.
I plan to modify the steering head angle. I have read a couple of posts and I will insert 6mm in the top tube for a 2 degree angle change.
But what about the swing arm? How much do I lengthen it out? Where should I make the cut - will it screw up the shock length?
If anyone has any pictures....
thanks!
I recall reading on one of the TLR specialist websites in the UK that they lengthen the swingarm behind the shocks in the axle mounting area. By doing so you keep the original shock location.
You are steeping the forks? I have a TLR250 and it appears to be less steep than a Reflex (yours is a Reflex?) from the riders position and I have no steering issues. Subjective opinion of course.
I see no need to lengthen the swing arm on my TLR200. I did find the bike to be quite top heavy and have lowered the peg mounts (1" down and 1" back) and it helped a lot. I did not steepen the forks because O still use it on the road and did not want it too twitchy.
Some people have suggested advancing the cam timing by about 6 degrees to wake up the sleepy motor. I have a new cam sprocket but have not installed it yet so no field report on that.
Have fun!
Have fun!
Hi, where did you find the cam sprocket?? thanks
I can't really remember where exactly I bought mine, but Dennis Kirk has 'em in stock -
https://www.denniskirk.com/51218.sku?utm_source=google&utm_medium=cse&gclid=COj54-et4rwCFYtDMgod_XsAvQ
It really woke up my 'Flux. LOTS more bottom-end oomph for $20 and about 45 minutes work.
