Beta Techno Rear Caliper
astra sxi
On the 99 Techno, the bleed nipple on the rear brake caliper has a ball bearing behind it, which acts as a sort of a valve seal. Without this ball bearing, it will not function properly. Apparently there is more than one type. I got one from BMV recently, but had to alter it a bit to make it fit. It did not come with a ball bearing, so I then had to find a ball bearing that would fit in the seat between the caliper and the bleed nipple. I found mine in the wheel of an old sack truck. Bleeding the bleeding rear brake is a real pain.
