Gasgas 80 Exhaust Removal
caldiboy
I wonder if someone could help me please?
I recently bought my lad a GasGas 80 TXT 2007, which is leaking oil on the joint between the first and second pipe.
I’ve bought new gaskets but cannot see how the front pipe is removed. Am I just being thick?!
Any help much appreciated before I get my big hammer out!
Thanks,
Steve.
i'm sure they are all very similar, take the two bolts out and then where the front pipe fits to the middle box it is push fit, i had no problem taking mine out but they can be hard to get back in, you have to make sure you clean where the rubber o rings sit in really good, make sure there is nothing that can stop the o rings from sitting right and i put some washing up liquid around the rings after fitting them, it was still tight but it went in after a bit of grunt.
