Rev3 Flywheel Thread Size
petert
Been a member for a while but lost log in details so had to reregister (age thing no doubt)
Anyway, after an 18 year lay off I have taken the plunge and bought a 2000 125 Rev3 to get back into trials. It is proving to be a bit of a bugger to say the least as it appears that early Rev3s are a bit of a bitsa.
My problem is that I need to remove the flywheel to change the main seals, however, the 30 x 1.5 puller I have doesn't fit!
It appears to be a smaller size and my question is does anyone know the correct size?
I have tried Lampkins and they can't remember! But did advise they are no longer available from Beta.
Thanks in advance
Pete
Yes it is! However, no one can tell me the thread size! I have established that it uses the earlier 125 engine from a Techno/Gara and ordered parts accordingly but am stuck with the above at the moment.
I have mic'd it up and it is 24 point something but knowing my luck I'd buy a 25mm puller and it would be a 24. I'm trying to get a definative answer to avoid ending up with a toolbox full of pullers!
Edited by petert
