carltile Posted March 1, 2014 Report Share Posted March 1, 2014 hi I just fitted a second hand rear wheel to my sherco (standard sherco morad rim with sherco hub) that has just been respoked but the offset is about 10mm out does any one know how I can pull it back in without removing the tyre thanks carl Quote Link to comment Share on other sites More sharing options...
copemech Posted March 2, 2014 Report Share Posted March 2, 2014 I had a wheel builder do this to me once, as the rim is not centered on the hub from factory. Requires some time, but if you back off the tight side spoke nipples and the pull it the direction it needs to go with the other side and do them all evenly, things should likely work out with a pull of a couple turns on each spoke nipple and equal reduction on the other side. 1 Quote Link to comment Share on other sites More sharing options...
carltile Posted March 11, 2014 Author Report Share Posted March 11, 2014 THANKS BUT I JUST HAD THE TYRE REMOVED TO SORT IT OUT DO YOU KNOW THE ACTUAL OFFSET FOR THE REAR WHEEL HAVE BEEN TOLD ITS 23MM FROM THE DISC TO EDGE OF THE RIM AND MY OFFSET MEASURES 33MM THANKS CARL Quote Link to comment Share on other sites More sharing options...
tony27 Posted March 11, 2014 Report Share Posted March 11, 2014 My spare wheel for the Jarvis which should the same from memory measures 28-29mm from the outside of the disc to the outermost edge of the rim depending on where I measure, is this the measurement you want? Disc thickness is 3mm which gets you close to the 23mm if you are going off the mounting surface for the disc Quote Link to comment Share on other sites More sharing options...
