Cota 311 Gear Oil
blademan98
Hi, I recently got back into trials and bought a 1997 registered Cota 311.
After a quick clean of the carbs she fired up and is great fun.
I noticed that the clutch was 'dragging' a little so I changed the gear box oil.
On draining it, I saw that it was AFT fluid and I have filled it up with the same.
All is working well, I just wondered if it is usual to use ATF instead of PJ1 or other 75W oil?
EDIT: just read a few other posts - should have done that before posting!
Cheers
Edited by blademan98
