penno350 Posted March 4, 2014 Report Share Posted March 4, 2014 Morning all. Physically fitted but no spark, could anyone please confirm for me stator connections to ignition unit (spade connectors) for blue and black leads. Also I have timed it at 5 degrees BTDC using the mark on the rotor with the closest mark on the stator. Apologies for really simple questions but didn't get any instructions with the system. Thanks. Quote Link to comment Share on other sites More sharing options...
penno350 Posted March 4, 2014 Author Report Share Posted March 4, 2014 (edited) Sorted the spade connectors as they are different sizes (should have gone to specsavers). Did a bit of googling and it seems to suggest that plug choice is critical, PVL doesn't like a standard plug? Should I be able to see a spark with the plug sitting on the head? Edited March 4, 2014 by penno350 Quote Link to comment Share on other sites More sharing options...
penno350 Posted March 4, 2014 Author Report Share Posted March 4, 2014 All sorted and running, thanks for the help :-) Quote Link to comment Share on other sites More sharing options...
bashplate Posted March 5, 2014 Report Share Posted March 5, 2014 Nice one Penno. Sometimes just voicing your thoughts helps clear your mind.....result, you find your own annswer. Quote Link to comment Share on other sites More sharing options...
sickswan Posted February 18, 2015 Report Share Posted February 18, 2015 Any info on what plug to use as I'm about to install my pvl from sammy miller also 5 degrees before top dead is that the point you line up the line on the rotor an stator? Instructions left alot to be desired!!! Quote Link to comment Share on other sites More sharing options...
