Ty 175 Crank & Main Bearing Stuck
mmmexico
I just split the cases on my TY 175. Everything went smoothly except when I finally freed the crank, the right side main bearing came with it. It is stuck right up against the flywheel. So far I've come up with the following bodges:
Put the crank in the freezer before re-installing it in the cases.
Warm up the cases and refrigerate the crank before re-installing
Use a torch on the case before re-installing.
I really don't want to destroy the main bearing, it feels perfect, but I don't relish the idea of trying to pound the crank and the main bearing back together...at least not without so heat and/or refrigeration.
Do you guys have any ideas??? As you all know, there is no room for a puller between the flywheel and the bearing...
Thanks in advance
Mike
That is a very cool tool. I even found a distributor in San Diego...unfortunately the tool is $173.00...plus I would pay roughly 1/3 more to import it to my home in Mexico....so it looks like a reach. What would a brand new crank cost???
I will certainly be replacing the seals (I have them in hand)...and the bearings if I can get this one off..
Thanks
Mike
Thank you lineaway......I'll be ordering from Harbor Freight just as soon as I post this supply. I've got a lot of stuff in my garage. Usually stuff that I will only use once...but I also got a hydraulic table to raise the bike up off the floor and some painting supplies..
Thanks again
Mike
