burnleytazz Posted March 6, 2014 Report Share Posted March 6, 2014 hi all. i was out last weekend and my throttle stuck open twiceso got in shed changed throttle cable and slide as the slide was badly worn making it stick open. i also cleaned carb and jets with carb cleaneri thought everything was fine throttle worked fine no sticking openso i got bike back out but its just not running right on half and full throttle. So back in shed thought reed petalsput new reeds in started it up and its stiill the samethe bike run fine before i changed cable and the slideplz plz plz Helpcould it be jetting can it just suddenly require differnt size jets plz help want to b playing this weekend Quote Link to comment Share on other sites More sharing options...
lineaway Posted March 6, 2014 Report Share Posted March 6, 2014 Do you have the clip in the top of the slide that holds the needle in place? Quote Link to comment Share on other sites More sharing options...
mokwepa Posted March 6, 2014 Report Share Posted March 6, 2014 No it wont be your jets. As above, make sure your slide/needle is assembled corectly. If thats not it, I would first change the pulg (cheap enough and eliminates that part) then check that you didnt create any air leaks removing and installing carb. You might also want to recheck that your pilot jet is clean and clear. Carb cleaner can blast gunk into places it shouldnt be. Im presuming you removed the jets to clean them properly or did you do the blast and hope its sorted stunt? Quote Link to comment Share on other sites More sharing options...
mokwepa Posted March 6, 2014 Report Share Posted March 6, 2014 Sorry I misread. Recheck your main jet. Also make sure your new cable is the same length and that your slide is opening all the way. A few mm of extra length will not le the bike rev out clean. Check throttle adjustment. Quote Link to comment Share on other sites More sharing options...
thats_a_five Posted March 6, 2014 Report Share Posted March 6, 2014 This does not sound like a vacuum problem or idle jet problem - those usually have a bigger effect on idle and slow running. It sounds like the clip that locates the needle in the slide may be at a different height than in the previous slide. Did you swap the needle from the previous slide to the new one? If it is a new needle, it may have a different taper than the old needle. Quote Link to comment Share on other sites More sharing options...
burnleytazz Posted March 6, 2014 Author Report Share Posted March 6, 2014 hi cheers for the fast replies lads the slide didnt come with a needle used the original the slide size is a 60 same as before i think the clip is positioned on the 2nd recess also the main jet is that the one holding float bowl on i removed and cleaned all jets except the one that spring up and down. i will strip down tomorrow re clean Quote Link to comment Share on other sites More sharing options...
burnleytazz Posted March 6, 2014 Author Report Share Posted March 6, 2014 also ive never messed with jettin before can jetting just suddenly alter the performance of your bike. is this how and when u know to change different jet sizes hope i dont sound stupid lol Quote Link to comment Share on other sites More sharing options...
zerorev3rev4 Posted March 6, 2014 Report Share Posted March 6, 2014 jetting can not suddenly change but after working on a bike you can upset something cause a blockage or air leak if the air flow changes it gives incorrect jetting symptoms if jets are incorrect for some reason it will run lean causing pinking running hot and a white plug ,running rich will cause it to be spluttery smokey wet out the exhaust black wet plug getting fouled and causing weak spark it sounds like something you have changed 1 Quote Link to comment Share on other sites More sharing options...
burnleytazz Posted March 6, 2014 Author Report Share Posted March 6, 2014 got that the bike is deffently running rich ive excess oil in exhaust fouling and wet plug and weak spark do u suggest i change jetting or needle clip position Quote Link to comment Share on other sites More sharing options...
burnleytazz Posted March 6, 2014 Author Report Share Posted March 6, 2014 so if i still have some dirt in carb or specifically one of the jets it could cause it to run richer than usual then causing bad running problems Quote Link to comment Share on other sites More sharing options...
zerorev3rev4 Posted March 6, 2014 Report Share Posted March 6, 2014 dirt in a jet will cause less fuel and run lean , it seems the needle is higher or the air is restricted ,,ie less air = running rich or if you restrict the exhaust it will run rich did you oil the filter Quote Link to comment Share on other sites More sharing options...
lineaway Posted March 6, 2014 Report Share Posted March 6, 2014 You never stated which bike you have. Did you understand my question about the needle being held in it`s location? That also could have been the cause of the throttle problem in the first place. Quote Link to comment Share on other sites More sharing options...
tltel Posted March 7, 2014 Report Share Posted March 7, 2014 wrong slide ! TLTEL Quote Link to comment Share on other sites More sharing options...
thats_a_five Posted March 7, 2014 Report Share Posted March 7, 2014 Jetting is very important to the running of the bike. When you changed the slide the 2 most likely things that would cause the symptoms you describe are: 1) the needle is set too high (clip too low on needle) 2) wrong slide. Whenever you have a symptom starts right after you change some part, the best place to start looking is at that new part. check: Is it the correct part? Is it installed the same as the old part? Is it adjusted correctly? Is the new part damaged or different from the old part? How did you determine that the slide was badly worn? Where did you get the new slide? Is the new slide EXACTLY like the old one except for the wear? If the slide is badly worn, then the carburetor bore is also likely to be worn. Most carbs are alloy and slide are steel. More likely the alloy will wear before the steel. Quote Link to comment Share on other sites More sharing options...
burnleytazz Posted March 7, 2014 Author Report Share Posted March 7, 2014 thnx to everyone who replied top lads air flow was restricted from my middle box and silencer i just took silencer off it was still same so took middle box off VERY LOUD but it revved out whoop whoop so poured petrol in burt all oil out and now ive got better throttle response than ever cheers to all Quote Link to comment Share on other sites More sharing options...
