jacaldo Posted March 6, 2014 Report Share Posted March 6, 2014 Hi, New to posting on this forum, so hello to all. I have a 2003 450 fse that has a faulty oil light, there is power to the sensor which seems to act as the earth, the light will not illuminate as normal with the ignition on. The fault seems to be the switch itself but I cannot locate one anywhere, the Spanish site does not list it either, it is at the back of the engine with a single wire attached. Has anyone had the same fault or do they know a supplier of this part. Many thanks Quote Link to comment Share on other sites More sharing options...
thats_a_five Posted March 6, 2014 Report Share Posted March 6, 2014 I have no specific knowledge of your bike, however, with only one wire to the switch, and only light (not a gauge) the sender is most likely an on/off switch. If you disconnect the wire from the switch and connect the wire directly to earth the light should come on (with the key on). Remove the wire from earth and the light should go off. I would suggest you find a GasGas dealer for the part. If no luck with the dealer, remove the switch and look for manufacturer info and part number then find a hydraulics parts distributor and take the switch with you. Quote Link to comment Share on other sites More sharing options...
jacaldo Posted March 6, 2014 Author Report Share Posted March 6, 2014 Thanks for replying, Yes the light does come on as you described, the problem is my local supplier has never been asked for one of these switches and I cannot find one on the Spanish web site fiche. The switch itself is not the usual type, it passes through a banjo jointed oil feed pipe before going into the engine so the thread is much longer than normal?? Quote Link to comment Share on other sites More sharing options...
thats_a_five Posted March 7, 2014 Report Share Posted March 7, 2014 Is this the part? http://www.outletgasgas.com/en/electric-parts/244-quad-left-upper-wishbone.html Quote Link to comment Share on other sites More sharing options...
jacaldo Posted March 7, 2014 Author Report Share Posted March 7, 2014 That's the baby, many thanks Quote Link to comment Share on other sites More sharing options...
thats_a_five Posted March 7, 2014 Report Share Posted March 7, 2014 You are welcome. Ride on! PS, you might want to edit your profile so we have an idea what part of the world you are in. It can help in giving you leads to where to find things. Quote Link to comment Share on other sites More sharing options...
jacaldo Posted March 7, 2014 Author Report Share Posted March 7, 2014 Can't find a way of editing my profile, when I go into the edit page the only change I can make is my email?? Quote Link to comment Share on other sites More sharing options...
jacaldo Posted March 7, 2014 Author Report Share Posted March 7, 2014 Found it now, I'll update soon Quote Link to comment Share on other sites More sharing options...
