ratty070183 Posted March 10, 2014 Report Share Posted March 10, 2014 Hi I am experiencing running & starting issues with my bike. I have had it 4 months now and when I got it it wasn't running to well so I cleaned the carb out & reset the carb as per gas gas u tube video this was all good running really sweet most of the time ,when u first go to start the bike it kicks 2nd kick & runs on choke then idles fine when choke off. While riding every now and again the bike just cuts out then it is a tw** to start seems to only kick over when I put the choke back on ???? This can also be the case if I stop the bike with the kill switch ! Does anybody have any advice or experienced trouble like this ??? Also is it common for the kick start to touch the peg on a full kick ???? Kind regards Daz Quote Link to comment Share on other sites More sharing options...
zerorev3rev4 Posted March 10, 2014 Report Share Posted March 10, 2014 if it starts on choke its not getting enough fuel from the pilot system ie pilot jet blocked or too small or the mixture screw is set wrong Quote Link to comment Share on other sites More sharing options...
tltel Posted March 10, 2014 Report Share Posted March 10, 2014 Yes have to agree.. clean the carb again, do you have an inline filter? it doesn't take much to block a pilot jet. Think the kickstart thing has been covered before, think its normal. TLTEL Quote Link to comment Share on other sites More sharing options...
