no balance Posted March 14, 2014 Report Share Posted March 14, 2014 Hello, I have a Wasp RT3 with a unit 500 Triumph engine in and would like to put a day light MOT on it. Has anyone used the mountain bike type speedo and horn with any success, if yes, what make are they. I have looked at a few on line but they seem to cheap to be any good !! but I would prefer a wire less one . I will have to fit a small battery for the stop light, so plan to used a led bulb to cut down on power drain (the electronic ignition has no charging provision), I could also connect the horn to it, so it only leaves the speedo to sort out. Regards, NB Quote Link to comment Share on other sites More sharing options...
woody Posted March 14, 2014 Report Share Posted March 14, 2014 You don't need a stop light or reflector for MOT You don't need a speedo for MOT You can use a bulb horn due to the age of the bike - assuming it is Pre-73 1 Quote Link to comment Share on other sites More sharing options...
jonboy883 Posted March 14, 2014 Report Share Posted March 14, 2014 Woody is spot on, except, if the horn was fitted from standard then it can be a bulb type, so to avoid any embarrassment get a Halfords 9v cycle horn, loud, cheap and passes the test. No lights, reflectors, speedo etc required. Remember, if it has knobblies , it won't go on the brake roller, so may have to be a rolling brake test on the road. If your trailering it there, take a helmet with you as the tester may want you in the chair to test....... Quote Link to comment Share on other sites More sharing options...
jonboy883 Posted March 14, 2014 Report Share Posted March 14, 2014 Don't know why I put the helmet bit on there, I thought it was an outfit, mis-read the unit bit !! Quote Link to comment Share on other sites More sharing options...
gasserguy Posted March 14, 2014 Report Share Posted March 14, 2014 As the guys say, you don't need a speedo, stop lights etc.. Just a horn. I and many others use one of these which has a 9 volt battery. http://www.ebay.co.uk/itm/ENDURO-BATTERY-POWERED-MOTORCYCLE-LOUD-MEGA-HORN-105db-ENDURO-MOTOCROSS-QUAD-MOT-/330919828890?pt=UK_Motorcycle_Parts&hash=item4d0c5bdd9a Quote Link to comment Share on other sites More sharing options...
no balance Posted March 14, 2014 Author Report Share Posted March 14, 2014 Thank you for the responses, but I should have made myself a bit clearer, I would like to know approximately what speed I'm doing, due to the local traffic police being, like dog **** used to be......everywhere ! 1 Quote Link to comment Share on other sites More sharing options...
bashplate Posted March 14, 2014 Report Share Posted March 14, 2014 (edited) Hi NB, the cycle speedo's are cheep because like most electronic gear they've come down in price...they also sell a lot so can keep the price down. Can't recommened any particular brand, but sure someone will soon. Edited March 14, 2014 by bashplate Quote Link to comment Share on other sites More sharing options...
jonboy883 Posted March 15, 2014 Report Share Posted March 15, 2014 I've used the Halfords own brand speedo on a converted MX bike.......make sure when fitting you take into account the profile of the tyre, not rely on the rim size and use a good quality glue when gluing on the magnet. It worked very well for the time I had the bike and better still, didn't get a ticket from the speed camera vans.! Quote Link to comment Share on other sites More sharing options...
old trials fanatic Posted March 15, 2014 Report Share Posted March 15, 2014 I think what people are trying to say is that the speedo is not an MOT issue but it IS an issue for the rider if using on the road and it comes under Construction and use regulations if I remember correctly. Surprised no body mentioned number plate either ? Quote Link to comment Share on other sites More sharing options...
no balance Posted March 16, 2014 Author Report Share Posted March 16, 2014 (edited) Thank you for the recommendations/advice, OTF is correct and after speaking to the Mot tester yesterday I will be taking his advice, which is to have the following:- Speedo, any type. Horn, any type, bikes after 73 (I think) have to have a continuous sound. Brake light. Number plate, it should be full size but that just would't be practical ( would it officer !!) I plan to make all of the following items as quick detachable as possible. Edited March 16, 2014 by no balance 1 Quote Link to comment Share on other sites More sharing options...
