elemetal Posted September 2, 2016 Report Share Posted September 2, 2016 I'll second what africajon said, Adrian did mine at the end of a trial, took 10 minutes. Contact him ahead of time so he knows to bring the laptop and battery. Bear Valley is in a couple of weeks and will be a blast, plan to ride it if you can. Quote Link to comment Share on other sites More sharing options...
lotus54 Posted July 5, 2017 Report Share Posted July 5, 2017 No- when you read the firmware version it shows it has a dual map. It doesn't not show details about how the map actually works (rich/lean/advance etc). Software is readily available, just the cables are not currently abundant. (Especially reasonably priced ones). Both ECUs use the same cable and software, just a different end for the 4 pin vrs 6 pin. Quote Link to comment Share on other sites More sharing options...
