Cuting Out
jgm
Just bought a 1981 jumbo bike runs fine for fist half hour the cuts out at low revs.It then will only start using the choke. It runs ok at high revs but cuts out at low revs. Anbody got any sugestions wether the problem is carb,coil or condensor. Any advice appreciated.
Thanks JGM
Edited by jgm
Definitely a carb issue, electrics are not to effected when the engine is warm, but the fuel/air mix is...
Have the carb sonically cleaned and get a new jet kit for it.
Is it the dell'orto, if so all parts are available online.....
Electrics can be affected by heat, particularly condensors and coils.
Thanks for all the advice.checked points and codensor, put in a new plug and cleaned all the jets in the carb today. Bike seems to be running OK again. I will remount the condensor under the tank next if any further problems.
JGM
