240 Plugs?
axulsuv
As the champion L 82 is hard to find anymore,what spark plugs do you gents run with a late model coil fitted to my 83 240 ? I just need input on a ngk or nd baseline to start with as I have lengthened my intake boot and run a K&N air filter, which so for has improved my off idle snap quite a bit...
thanks, Glenn ;):wacko:
I'm running a B5HS now, but it had a BP4HS in it when I got her,w/the stock coil. What is the difference between a B# and a BP#? I know in ngk the smaller # is a hotter plug.
And I built a air box to fit the K&N I used!
thanks; ;):wacko:
Glenn
