cactusjack Posted March 22, 2014 Report Share Posted March 22, 2014 So here is a little tip for those that don't know on how the Kickstart 1/4 gear on the TXT Pro models needs to be timed in relation to the spring. I spent 2 frustrating hours installing the shaft wrong until I figured out what I had done. Andy, may you consider this to be a sticky? The following photo's show the timing for the gear in relation to the spring. Once I had sorted the timing, the kickstart went in very easily. This video explains the action required to mount the kickstarter: http://youtu.be/A80n7zq80n8?t=1m55s 1 Quote Link to comment Share on other sites More sharing options...
lineaway Posted March 22, 2014 Report Share Posted March 22, 2014 This is correct. 1 Quote Link to comment Share on other sites More sharing options...
lineaway Posted March 22, 2014 Report Share Posted March 22, 2014 (edited) You have the gear timed wrong. This is a picture from Gas Gas. The gear rotates up clock wise in the picture. I cheat as I have one in my hand. Edited March 22, 2014 by lineaway Quote Link to comment Share on other sites More sharing options...
cactusjack Posted March 22, 2014 Author Report Share Posted March 22, 2014 I was sent that picture from the Gas Gas importer also. It went together well and works like a dream. It would appear we are both right. I do remember now on assembly the gear rotated clockwise though. Although, the two pictures are only one tooth out from each other. My spring was a little worn I guess and didn't line up exactly the same as either picture, so mine actually timed somewhere in between the two, but worked perfectly. I don't think either are wrong. This wasn't meant to be a s h i t flinging match, just some useful information for others to stop them going through the same headache as I did. 1 Quote Link to comment Share on other sites More sharing options...
lineaway Posted March 22, 2014 Report Share Posted March 22, 2014 The only reason I said anything is you asked for this to be pinned. 1 Quote Link to comment Share on other sites More sharing options...
