casperrasper Posted March 23, 2014 Report Share Posted March 23, 2014 My 2013 ...300cc factory replica ...problem.... When I do a hill climb the bike seems to go lean and pink when I get to the top it smokes heavy for a while ..then goes ok till the next good climb ..apart from this the bike runs sweet ... ..someone told me today could be a problem with these bikes...any ideas Quote Link to comment Share on other sites More sharing options...
telecat Posted March 23, 2014 Report Share Posted March 23, 2014 I presume the problem occurs when revving it to the maximum? The Problem could be one of a couple of things. Simpleiest two They are supposed to run on 98 RON fuel not standard unleaded. The Air Screw on the Kehin should be about 1.5 to 2.5 turns out the Further in the Richer it runs. However the Main Jet looks to be the probable culprit so you may need to go up slighly on the jet size. Quote Link to comment Share on other sites More sharing options...
laser1 Posted March 23, 2014 Report Share Posted March 23, 2014 Not an inherent problem. Most likely Jetting related as stated above. Quote Link to comment Share on other sites More sharing options...
casperrasper Posted March 23, 2014 Author Report Share Posted March 23, 2014 It happens if I'm even on quater throttle ..the air screw was 1 quater turn out ...needle clip third from bottom ...someone reckons it could be cranks seal ..but I'm no mechanic so no idea Quote Link to comment Share on other sites More sharing options...
baldilocks Posted March 23, 2014 Report Share Posted March 23, 2014 Keihin runs better either fourth needle notch from top or with the washer supplied by splatshop under the needle clip and the clip in the third notch. Some also find 48 pilot jet is better than 45 std. Also sounds like your bike needs a clean out, may just be residual oil in the exhaust burning on a climb. If its crank seal you should notice oil level dropping week to week. Quote Link to comment Share on other sites More sharing options...
laser1 Posted March 23, 2014 Report Share Posted March 23, 2014 (edited) Could be crank seals, but pretty uncommon on GG's. Check for leaks. Clean the carb real well as a 1st step. (Check pilot for clogs) +1 on 48 pilot. Edited March 23, 2014 by laser1 Quote Link to comment Share on other sites More sharing options...
casperrasper Posted March 23, 2014 Author Report Share Posted March 23, 2014 I will try 48 pilot .having the clip on needle higher does thatmake it leaner . So I need clip on second up from bottom is that right Quote Link to comment Share on other sites More sharing options...
baldilocks Posted March 23, 2014 Report Share Posted March 23, 2014 Yes lower the clip to richen the mix. By the way is the fan working ? Quote Link to comment Share on other sites More sharing options...
casperrasper Posted March 23, 2014 Author Report Share Posted March 23, 2014 Ye the fan working fine no overheating problem . I will try what u said thanks for input Quote Link to comment Share on other sites More sharing options...
the dabster Posted March 23, 2014 Report Share Posted March 23, 2014 On 3/23/2014 at 4:32 PM, casperrasper said: My 2013 ...300cc factory replica ...problem.... When I do a hill climb the bike seems to go lean and pink when I get to the top it smokes heavy for a while ..then goes ok till the next good climb ..apart from this the bike runs sweet ... ..someone told me today could be a problem with these bikes...any ideas I have a 2013 / 250 factory bike and plagued with exact problem, rattle under load on hill climb (not noticed the smoke part). I have already changed to the 48 pilot, needle and splatshop washer on the second bottom position and changed to thinner needle (ggj from ggh STD?) but still the same problem. I was given a spare main jet with the bike (125) which I have not tried as yet. Not sure what size the STD main is. Crankcase oil level not moved at any time but changed very regularly. I was brought up on two strokes and love the factory but have to admit I am for the first time tempted to try a 4RT because of this! Tried every thing other than the 3,0 slide and would not be surprised now to find Mains problem.. Few weeks ago bike started choking on idle like fuel was switched off which was transiently mitigated by use of the choke... not happy! Quote Link to comment Share on other sites More sharing options...
the dabster Posted March 23, 2014 Report Share Posted March 23, 2014 by the way fan working and bp ultimate fuel. Quote Link to comment Share on other sites More sharing options...
jacksongee Posted March 23, 2014 Report Share Posted March 23, 2014 (edited) Could be an issue with the floats or needle valve, check the floats don't contain fuel and consider changing the needle valve, also check the float arm for bending. It could also be worth sending off the carb to be ultrasonically cleaned to help clear any hidden debris, how much work has the bike actually done? PS what fuel:oil ratio are you running and has this problem always existed or has it just started to happen? Edited March 23, 2014 by jacksongee Quote Link to comment Share on other sites More sharing options...
the dabster Posted March 23, 2014 Report Share Posted March 23, 2014 What is the official float height settings and method of measurement? Has been doing it for months, 80ml oil to five ltd petrol. Quote Link to comment Share on other sites More sharing options...
casperrasper Posted March 24, 2014 Author Report Share Posted March 24, 2014 I've been putting 75 ml oil to 5ltr fuel . Must say I been using standard fuel tho .i will give factory Kev at gguk a ring see if he I can shine a light on it .. Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted March 24, 2014 Report Share Posted March 24, 2014 I run 65 to 5 ltrs but that shouldnt make much difference, its worth noting that the needle height works only for the first 1/3 rd of throttle opening I think. Quote Link to comment Share on other sites More sharing options...
