Best Type Of Rim Tapes?
twinkletoes
S3 give by far the best protection to your rims. Make sure your rims are nipping clean before fitting and make sure you warm them with a hair dryer or if you use a paint stripping gun be careful not to overheat them. Take your time fitting and I'm sure you will be happy wi' um.
If you fasten a valve stem in with a couple of nuts and sealing washers on the inside and then smear sikaflex or other neutral cure sealer on the valve and all the spoke nipples you can do away with the rim tape altogether.
The sealer replaces the rim tape
Rim has to be well cleaned first
