348 Carb And Shock Length
smelling123
Try Sandifords (they moved not long ago but I think they are still in Bury) for info.
The carb was an Amal Mk2 but I an't remember if it was 26 or 27mm I can't remember the jet sizes either but stock jetting was pretty well spot on, Maybe a tweak on the air screw and a notch on the needle clip between summer and winter and that was about it.
Engine is good but check for damage in upper rear of ignition side of crankcase caused by miss fitting of kickstart
I think shock length is 13.4 inch
Edited by dadof2
