rohls Posted April 9, 2014 Report Share Posted April 9, 2014 Hello, I recently purchased a 1996 JTR 250 Gas Gas. Very sweet, but the wiring for the main kill/light/horn switch is cut. I have a new switch, but would desperately need to look at a wiring diagram. ANy one have a basic one I could have? Even a 'green=ground' type would be of huge help here. Also, where is the best place to buy parts for this beast? I have looked just about everywhere and they are scarse to say the least. Many thanks, Rohls Quote Link to comment Share on other sites More sharing options...
jonboy883 Posted April 9, 2014 Report Share Posted April 9, 2014 Go onto the Gas Gas UK site and click the support tab. Then tap on manuals, and find your bike. Most of the manuals have a wiring diagram. Also try YouTube, as there are some Gas Gas fix it videos on there also. Quote Link to comment Share on other sites More sharing options...
bilks Posted April 9, 2014 Report Share Posted April 9, 2014 Any help to you, Quote Link to comment Share on other sites More sharing options...
thats_a_five Posted April 9, 2014 Report Share Posted April 9, 2014 It would help if we knew where you are located so we can direct you to parts that might be on the same continent. Quote Link to comment Share on other sites More sharing options...
rohls Posted April 9, 2014 Author Report Share Posted April 9, 2014 Thanks for the reply! I am in Central California, USA. The attached 'KOKUSAN SYSTEM Wiring diagram' is helpful, though the RED WIRE to 'LIGHTS< HORN AND OTHER ACCESORIES' is not that helpful :/ I have a seven wire connector that goes to the light/horn/kill switch (multiswitch)...I had to replace the oringal switch (which I have with some cut wires) with a very similar one. Can you guys tell me what color wires go to what..? RED = Positive, BLACK = ground....what's YELLOW? What's GREEN/YELLOW? What's GRAY? What's WHITE? What's BROWN?...etc. Not to complicate the issue, but I'm not able to fire it up in it's current state, SO I'd like to have the switch wired up with confidence before I button her up again. Thanks in advance Quote Link to comment Share on other sites More sharing options...
bilks Posted April 9, 2014 Report Share Posted April 9, 2014 Sorry my mistake thought u just wanted to wire a kill switch. Quote Link to comment Share on other sites More sharing options...
lineaway Posted April 10, 2014 Report Share Posted April 10, 2014 So did it run before you tried the switch? Those were very unreliable, and for trials everything in the states were removed as they were not road legal. Quote Link to comment Share on other sites More sharing options...
rohls Posted April 10, 2014 Author Report Share Posted April 10, 2014 Thanks for the reply. So did it run before you tried the switch? Those were very unreliable, and for trials everything in the states were removed as they were not road legal. Thanks; yup runs with the switch disconnected....just doesn't have the kill switch option then. I have another new and similar switch and am trying to hook up the lights, horn and kill switch again....so yeah. That's where I'm at. Quote Link to comment Share on other sites More sharing options...
jse Posted April 10, 2014 Report Share Posted April 10, 2014 Some 96's (most) came with the Ducati analog system, like the 96 JTR370 I had: http://www.trialspartsusa.com/diagrams/Duc94to96.jpg . Jon Quote Link to comment Share on other sites More sharing options...
rohls Posted April 10, 2014 Author Report Share Posted April 10, 2014 Some 96's (most) came with the Ducati analog system, like the 96 JTR370 I had: http://www.trialspartsusa.com/diagrams/Duc94to96.jpg . Jon Thanks, though this doesn't really help much...:/ Quote Link to comment Share on other sites More sharing options...
lineaway Posted April 11, 2014 Report Share Posted April 11, 2014 I doubt you will find a wiring diagram as info was scarce even when new. And most of the Euro bikes did not follow a color code. Quote Link to comment Share on other sites More sharing options...
thats_a_five Posted April 11, 2014 Report Share Posted April 11, 2014 I have seen 2 different wiring diagrams for that say they cover 1996. One is the Kokusan that Bilks posted. Here is the Ducati system. On both, you will notice that the kill switch is wired to the ignition module which is wired to the ignition windings of the stator and the spark timing sensor. All other electrics come from the "lighting" coil of the stator. That feeds to the voltage regulator and fan, and has a red wire that feeds to "all other accessories." From there, all I can suggest is chase the wires with a voltmeter to see what color goes to what accessory and make your own diagram. There are only horn, headlight and taillight, right? You say you have a "similar" switch, not an exact replacement. Again, use your VOM and figure out the what colors go to what things and make your own diagram. If you know what bike the switch came from, you might be able to get a wiring diagram for that bike. Pretty hard for us to help without being hands on with the bike. Don't ride without a kill switch even if you have to wire up a separate one. Quote Link to comment Share on other sites More sharing options...
