Sprockets
catchoreno
Mmmh 57 teeth, not commen ... I recently ordered a custom sprocket too Wüdo make custom sprockets in every teeth number in aluminium, numbers ad pattern for fasteners as requested, inner hole diameter too even a recess if in need. Last not least the would even mill a recess in the srocket if you need. The aluminium sprockets can too be anodized in many colors.
http://www.wuedo.de/menu_main/index/pdf/kettenrad_fertigung_form.pdf
Adress and contact data: http://www.wuedo.de/menu_main/index/index.html
Edited by pschrauber
