kenny123 Posted July 20, 2005 Report Share Posted July 20, 2005 the clutch seems to be dragging since i have got the bike back from an engine rebuild i have turned the pin in on the clutch lever but nothin seems to happen. could it be because the bike has not been used in a while? Quote Link to comment Share on other sites More sharing options...
gasgas Posted July 21, 2005 Report Share Posted July 21, 2005 (edited) You have to ask them what they changed cq did. But to give a few hints. Maybe you not getting enough pressure at the slavepiston: bleed the system, and maybe you have to fiddle with the masterpiston. Cld be too thick a clutch pack causing it not to free completely when you engage lever: get smaller discs. succes ps: refering to the clutch pach, i am talking about the pro here Edited July 21, 2005 by gasgas Quote Link to comment Share on other sites More sharing options...
grib Posted July 21, 2005 Report Share Posted July 21, 2005 Have you changed to a different type of oil? pro clutches will drag badly if the wrong oil is used. Quote Link to comment Share on other sites More sharing options...
kenny123 Posted July 21, 2005 Author Report Share Posted July 21, 2005 is it easy to bleed a clutch. wat oil do you recomend Quote Link to comment Share on other sites More sharing options...
kenny123 Posted July 21, 2005 Author Report Share Posted July 21, 2005 its a pro. the side cover as not been of for a long time. but it is dragging a lot more than it used to. wen the clutchi is out ther is a loud noking noise aswel but wen i pul it in the noking stops. Quote Link to comment Share on other sites More sharing options...
kenny123 Posted July 21, 2005 Author Report Share Posted July 21, 2005 ok cheers. is there a chance that if i keep riding it that the clutch will stop draging as much or not Quote Link to comment Share on other sites More sharing options...
jtt Posted July 22, 2005 Report Share Posted July 22, 2005 ok cheers. is there a chance that if i keep riding it that the clutch will stop draging as much or not Not. You need to fix the problem. The link r2 gave you should provide enough info to sort you out. If you have been running "non-compatible" oil, then plate replacement may be in order, but try all the other things first. Quote Link to comment Share on other sites More sharing options...
kenny123 Posted July 23, 2005 Author Report Share Posted July 23, 2005 been out on my bike today. i hadnt been out more than 15minutes when the cltuch started slipping??????? i could ride very slowly but when i got a bit faster it just reved and didnt go anywhere. Quote Link to comment Share on other sites More sharing options...
gasgas Posted July 24, 2005 Report Share Posted July 24, 2005 glad we cld help with yr dragging problem, Quote Link to comment Share on other sites More sharing options...
kenny123 Posted July 25, 2005 Author Report Share Posted July 25, 2005 it jus feels like normal. the ajuster was half way in so i have loosend it and cable tied the lever back to the bar cheers Quote Link to comment Share on other sites More sharing options...
